This lesson covers the critical aspects of mathematical modeling in welding processes, focusing on the heat source model in conduction mode welding. It delves into the representation of different heat sources, such as in arc welding, laser link processes, electron beam welding, and friction state welding. The lesson also discusses the interaction of heat sources with surfaces and their penetration into the depth of the weld pool or substrate material. It further explores the integration of heat source models in the modeling of welding processes, including solid-state dwelling processes and keyhole formation.
01:00 - Different sources of heat in various welding processes such as Arc welding, laser link processes, and electron beam modeling process
07:54 - Concept of distortion in welded structures due to differential expansion and thermal expansion
14:31 - Need for correct representation of heat source in thermal mechanical model
33:26 - Representation of heat source in resistance welding process
45:15 - Analytical solution of temperature distribution in welding process
- Heat sources interact differently with surfaces and can penetrate into the depth of the weld pool or substrate material.
- The integration of heat source models in the modeling of welding processes is essential.
- The heat affected zone, which is below the melting point temperature, undergoes solid-state transformation.
