The standard mesh for the geometry works pretty well; we simply need to apply a refinement.
The first step is to attach a static structural model to the geometry. Simply drag the option from the toolbox and drop it onto the geometry. Open the model.
First, select Mesh and open up Sizing. Select Advanced Size Function and change it to "On: Curvature."
The defaults for the Curvature sizing work well.
Now, there are two types of sizing that should be applied. First off is the sizing of the base mount pad. The pad does not have much motion or deformation, so it does not need as many elements as the default setting.
Add a sizing and apply the base mount pad as the geometry. Select the behavior as Hard, and the element size as 0.05m. This should reduce the number of elements on the base pad.
Now we need to refine the insides of the flexure mounts. Currently, they do not have enough elements, since they deform greatly. Add a face sizing and apply the face sizing to the two inside faces of the flexure mounts.
Set the element size to 0.002 m. Repeat to create a face sizing on all the flexure mounts.
Once applied, generate the mesh. After it is done, it should look somewhat like this:
