This lesson covers a two-way coupling simulation between the Ansys HFSS and Ansys Icepak in AEDT student version for ETM. It shows the HFSS model preparation steps to make the design ready for two-way coupling with Icepak. In this lesson, two-way coupling using both EMtoIcepak ACT extension and step by step methods are demonstrated.
This lesson also describes the key elements that are required to do two-way coupling, which includes the thermal modifier, temperature dependency, and thermal feedback that are required to be set up in Ansys HFSS. In this lesson, the setup required for two-way coupling in Ansys Icepak is also described. This lesson also emphasizes the rise in temperature due to the temperature dependency of the material used.
To download Ansys Electronics Desktop Student version for free, click here.
