Viscous Flow in Capillary — Lesson 3
This lesson covers the concept of flow through porous media, focusing on the calculation of Reynolds number and its application in determining pressure drop. It introduces alternative ways to express pressure drop as a function of flow rate, beyond the commonly used Darcy's law. The lesson further delves into the derivation of equations such as Kozeny Carmen, Blake Pummer, and Ergun equations. It also explains the concept of friction factor and its application in calculating pressure drop in a capillary. The lesson concludes with the introduction of the friction factor chart and its application in turbulent flow.
Video Highlights
00:53 - Derivation of Kozeny Carman, Blake Pummer, and Ergun equations
11:09 - Understanding of friction factor and its application in capillary flow
25:35 - Explanation of the friction factor chart and its use in turbulent flow
Key Takeaways
- The Reynolds number is crucial in determining the pressure drop in porous media.
- The friction factor is a key concept in understanding flow through a capillary and is used to calculate the pressure drop.
- The friction factor chart is a useful tool in understanding and calculating frictional pressure drop in turbulent flow.
- The concept of flow through porous media can be extended to other areas, such as the calculation of Reynolds number for porous medium.
