Double Layer Full Pitch Winding — Lesson 4
This lesson covers the principles of stator winding design, focusing on full pitch double layer winding. It explains how to select the coil pitch, number of coils, and create a winding diagram using the stubbing and arrow check approach. The lesson uses a 24 slot, 3 phase, 4 pole double layer winding as an example to illustrate the process. It also discusses the Faraday's law of voltage equation, the selection of copper gauge based on current rating, and the verification of magnetic poles using the right hand thumb rule. This lesson also covers the stubbing and arrow check methods for winding connections. The lesson concludes with a detailed explanation of how to make star and delta connections and test the machine under operating conditions.
Video Highlights
00:00 - Introduction to stator winding design
00:29 - Explanation of full pitch double layer winding
11:08 - Stubbing method for winding connections
14:18 - Connecting winding and terminals using arrow check representation
22:02 - How to make stubbing?
Key Takeaways
- Understanding the principles of stator winding design is crucial for efficient machine operation.
- The selection of coil pitch and number of coils is determined by the machine's specifications and operating conditions.
- The stubbing and arrow check approach is a reliable method for creating a winding diagram.
- Verification of magnetic poles using the right hand thumb rule ensures the correct functioning of the machine.
- Making star and delta connections and testing the machine under operating conditions are the final steps in the stator winding design process.
