Electrical Design of Battery Packs - I — Lesson 1
This lesson covers the electrical design of battery packs, focusing on the importance of bus bar design, contact resistance, voltage drop, current equalization, and conductor selection. It explains the process of assembling cells into modules and then into a battery pack, highlighting the significance of parallel and series combinations. The lesson also discusses the impact of resistance on power delivery, efficiency, and safety. For instance, it illustrates how a poorly designed bus bar can lead to overheating, structural damage, and even fatal accidents. The lesson further delves into the selection of conductor materials, thermal considerations, and the characteristics of bus bar materials.
Video Highlights
00:21 - Introduction
00:34 - Type of cells used in a battery pack
02:16 - How cells are combined to make modules
07:41 - How to assemble modules to make a pack
10:15 - Issues that need to be addressed in a bus bar
13:46 - Why busbar design is important?
17:11 - Things required for electrical design of a battery pack
19:52 - How to reduce contact resistance
21:17 - Importance of voltage drop and current equalization
22:24 - Current equalization and busbar joining methods
23:21 - How to select conductor
Key Takeaways
- The electrical design of battery packs involves assembling cells into modules and then into a pack, using parallel and series combinations.
- Resistance plays a crucial role in power delivery, efficiency, and safety. A poorly designed bus bar can lead to overheating, structural damage, and safety compromises.
- Conductor material selection is critical for electrical performance and should have low electrical and thermal resistance.
- Thermal considerations are important in bus bar design to ensure excess heat generated during power delivery can be vented out.
- Voltage drop and current equalization are key factors in the design process to ensure efficient power delivery and safety.
- The bus bar material should have high mechanical strength, low electrical resistance to surface films, and high resistance to cyclic failures.
