Output Power (D2.5L) Product Equation — Lesson 9
This lesson covers the sizing equations of electrical machines, focusing on the (D2.5L) sizing equation. It also discusses the importance of considering rotor geometry, including flux densities at different parts of the rotor core and the actual current density of the rotor. The lesson further explains how to derive power equations based on these factors. For instance, it elaborates on how to calculate the slot area of the rotor and find the flux density values at the teeth, air gap, and back iron. The lesson concludes by discussing the procedure for deriving power equations on the rotor side.
Video Highlights
00:00 - Introduction
00:45 - Derivation of power equations
01:23 - Explanation of output power equations with respect to stator
05:13 - Considering the equations on the rotor side
10:12 - Final power equation
Key Takeaways
- Understanding the sizing equations of electrical machines is crucial for determining the dimensions of the machine.
- The rotor geometry, including flux densities at different parts of the rotor core and the actual current density of the rotor, plays a significant role in deriving power equations.
- The slot area of the rotor, flux density values at the teeth, air gap, and back iron are essential parameters in the calculation.
- The same procedure used for deriving power equations on the stator side can be applied to the rotor side.
