This lesson covers the various systems and configurations of electric vehicles (EVs). It delves into the multidisciplinary engineering domains required for EV systems, including electrical, mechanical, and chemical engineering. The lesson discusses the different types of EVs, such as converted EVs and purpose-built EVs, and their respective designs. It also explains the components of a typical EV system, including the electrical propulsion system, energy source subsystem, and auxiliary power supply. The lesson further explores the different types of mechanical arrangements in a typical BEV system, the differences between single motor and multiple motor-based BEV configurations, and the decision-making process for system voltage in BEV configurations. For instance, a converted EV is an existing vehicle that has been modified to function as an EV, while a purpose-built EV is designed from scratch to be an EV.
01:53 - Exploring Various EV Types and Designs
07:53 - Understanding Typical EV System Components
14:33 - Examining BEV System's Mechanical Arrangements
29:53 - Comparing Single vs. Multiple Motor BEV Configurations
40:31 - Decision-making process for system voltage in BEV configurations
- EV systems require knowledge from multiple engineering domains.
- There are different types of EVs, each with its unique design and configuration.
- The components of a typical EV system include the electrical propulsion system, energy source subsystem, and auxiliary power supply.
- The design of an EV can vary based on the type of propulsion system used, the type of energy sources used, and the charging system.
- The decision for system voltage in BEV configurations is influenced by factors such as cost, size, and performance.
