This lesson covers the bending analysis of a composite cylindrical shell using Abaqus software. The lesson is led by Shranish Kar, a research scholar at the Smart Structures and Materials Lab, IIT Guwahati. The lesson begins with the problem of finding the three-dimensional stresses and displacements of cylindrical shells made of laminated composites under specific pressure and boundary conditions. The lesson then proceeds to demonstrate how to create a model, set work directories, dimension surfaces, create plies, set material properties, and assign sections. The lesson also covers how to set up a static analysis, apply loads, set boundary conditions, and mesh the part. Finally, the lesson concludes with how to analyze the results, visualize the results, and compare them with an exact solution.
03:53 - Steps to create the set work directory
09:23 - Setting of boundary conditions and displacement and rotation type
13:14 - Transformation of results to the local coordinate
16:33 - Comparison of the numerical results with the exact solution
18:22 - Creation of an XY plot along the path
- Understanding the problem and setting up the work directory are crucial first steps.
- The model creation process involves defining the material properties and setting up the analysis.
- The results of the analysis need to be carefully analyzed and compared with the exact solution to ensure accuracy.
- The bending analysis of a composite cylindrical shell can be conducted using Abaqus.
