This lesson covers the concept of crosstalk or near field coupling, a phenomenon where one circuit interferes with the functioning of another due to a common impedance. The lesson is divided into six modules, starting with an introduction and definitions, followed by an exploration of common impedance coupling, capacitive coupling, and inductive coupling. The lesson also delves into different types of crosstalk combinations and low-frequency analysis in shielded wires. It further investigates the interaction of electromagnetic fields with electrical circuits, particularly in the context of noise pickup from PCB lands and component leads. The lesson concludes with exercises and practical examples, such as crosstalk in power lines and printed circuit boards.
00:13 - Content and introduction to crosstalk or near field coupling
07:17 - Explanation of three conductor system
10:44 - Illustration of Common impedance coupling
16:28 - Calculation of signal to noise ratio
19:31 - Explanation of common impedance coupling as series voltage source
21:40 - Mitigation of coupling due to common impedance
- Crosstalk or near field coupling is a phenomenon where one circuit interferes with another due to a common impedance.
- There are three distinct phenomena in near field coupling: common impedance coupling, capacitive coupling, and inductive coupling.
- Crosstalk can occur in various practical scenarios, such as power lines, printed circuit boards, and communication lines running parallel to each other.
- The goal is to find a transfer function for the coupling phenomena to understand the influence of common impedance on voltage.
- Mitigation of crosstalk can be achieved by eliminating the common impedance, for instance, by not sharing long or large ground cables or planes and using separate conductors.
