Connecting Parts of an Assembly Together - Lesson 1
This lesson explores two different options for defining interaction between neighboring parts in an assembly. Shared Topology or Contact definition settings solve the problem of connecting parts efficiently in Finite Element Analysis. Simulation results can be misleading or incorrect when neither of these options is used manually because the part interaction is not assumed by the program.
Video Highlights
1:40 - Connecting parts using Shared Topology in Ansys Discovery
3:16 - Connecting parts using Contact Connections in Ansys Mechanical
4:40 - Choosing the right method for connecting parts
7:50 - Using the “Share” tool for Shared Topology in Ansys Discovery
9:10 - Visualizing Shared Topology with “Show Connected Bodies” in Ansys Discovery
13:33 - Demonstration of use of Contact Connections
17:13 - Modifying the Legend of Contour Displays using Top and Bottom Independent Bands
Simulation Files
Download the accompanying geometry and archived files here. Ansys Student can be downloaded for free here.
