Normal Shocks, Mach Waves and Oblique Shocks — Lesson 4
This lesson covers the concept of normal shock waves and mark waves in the context of compressible flow. It delves into the hypothetical state changes of a compressible flow, the characteristic mach number, and the concept of stagnation conditions. The lesson also introduces the energy equation from a calorically perfect point of view. It further discusses the concept of isentropic slowdown and the impact of a normal shock on mach number, density, velocity, pressure, temperature, and enthalpy. The lesson concludes with an introduction to mark waves and oblique shock waves. For instance, it explains how a supersonic flow becomes subsonic on crossing a normal shock.
Video Highlights
02:05 - Discussion on the concept of isentropic slowdown and stagnation conditions.
05:23 - Discussion on the changes in mach number, density, velocity, pressure, temperature, and enthalpy across a normal shock.
13:50 - Introduction to mark waves and their formation due to weak disturbances in a stagnant medium.
21:11 - Explanation of the concept of oblique shock waves and their formation due to strong disturbances.
30:10 - Discussion on the conservation equations applied to a control volume in the context of oblique shock waves.
Key Takeaways
- Normal shock waves and mark waves are crucial concepts in understanding compressible flow.
- The characteristic mach number and stagnation conditions play a significant role in the state changes of a compressible flow.
- The energy equation provides insights into the calorically perfect perspective of these flows.
- Isentropic slowdown is a significant concept that affects the velocity and static part of the flow.
- A normal shock has a profound impact on the mach number, density, velocity, pressure, temperature, and enthalpy of the flow.
- Mark waves and oblique shock waves are introduced as advanced concepts in the study of compressible flows.
