Design of Stator Core — Lesson 3
This lesson covers the process of designing induction machines, focusing on the initial design data, sizing equations, and stator core design. It explains the importance of selecting the type of machine, rotor, and standards to follow, as well as the basic specifications such as output power, efficiency, torque, speed, and number of phases. The lesson also discusses how to calculate the main dimensions of a machine, including the inner diameter of the stator, length of the core, and outer diameter of the stator. It further delves into the selection of magnetic loading and electric loading values, the calculation of the number of slots, and the choice of winding type. An example of designing a high power machine is provided for better understanding.
Video Highlights
00:00 - Introduction
00:16 - Discussion on initial design data
01:44 - Explanation of sizing equations and main dimensions
09:13 - Selection of magnetic and electric loading values
18:35 - Stator core design and calculation of the number of slots
34:39 - Choice of winding type
Key Takeaways
- The design of induction machines involves several steps, including the selection of initial design data, calculation of sizing equations, and design of the stator and rotor core.
- The main dimensions of a machine, such as the inner diameter of the stator, length of the core, and outer diameter of the stator, are crucial in the design process.
- The selection of magnetic and electric loading values is based on the power rating and type of cooling mechanism.
- The number of slots and the type of winding are determined based on the power rating of the machine and the desired output.
- The lesson provides a practical example of designing a high power machine, demonstrating the application of the discussed concepts.
