This lesson covers the principles of transmission of mechanical energy in Internal Combustion (IC) engine-based vehicles and contrasts it with the motor drive technologies used in Electric Vehicles (EVs). It explains how IC engines require the support of a clutch and multiple transmission gears to operate in wide torque and speed regions, while electric motors for EVs can provide high torque at starting and enable high-speed operation without the need for a clutch or variable gears. The lesson also discusses the design requirements of a typical EV motor, the different types of EV motors used, and their respective advantages and disadvantages. For instance, it highlights how Permanent Magnet Synchronous Machines (PMSM) are preferred for EV applications due to their high torque density, power density, and efficiency.
00:27 - Introduction to motor drive technologies in EVs
05:45 - Design requirements of a typical EV motor
09:15 - Different types of EV motors used for electric vehicle applications
11:48 - Use of synchronous machines in EV applications
14:21 - Use of synchronous reluctance motors and doubly-salient motors in EV domain
- IC engines require the support of a clutch and multiple transmission gears to operate in wide torque and speed regions, while electric motors for EVs can provide high torque at starting and enable high-speed operation without the need for a clutch or variable gears.
- The design requirements of a typical EV motor include high torque density, high power density, wide speed range operation, high efficiency, high reliability, and robustness.
- Different types of EV motors include commutator motors, commutator-less motors, induction machines, synchronous machines, and doubly-salient motors, each with their own advantages and disadvantages.
