This lesson covers the principles of speed control in series motors, focusing on the control of applied voltage and field current. It explains how series motors are used in traction due to their ability to provide large starting torque. The lesson also discusses the use of multiple DC motors at the start and how they can be connected in series or parallel to control speed. It further delves into the concept of reversing the supply voltage and the impact on the direction of the motor. The lesson concludes with an exploration of the use of AC supply in DC series motors and the conditions under which this is possible.
00:58 - Discussion on the use of series motors in traction
11:52 - Explanation on why a shunt motor will not work with an AC supply
20:59 - Discussion on the possibility of operating a series motor with an AC supply
26:15 - Discussion on the performance of a series motor when operated from an AC supply
30:23 - Conclusion of the lecture and introduction to the next topics
