Special Script Commands for Working with FDE Data — Lesson 4
While using the GUI works fine in most cases, script commands can be used to replace tediously repetitive jobs or to perform a custom analysis. Here are some of the key script commands for FDE analysis:
Getting the Calculation Parameters of Eigensolver Analysis Window:
Command
Syntax
Description
getanalysis ?getanalysis; Lists all the parameters in the analysis window.
getanalysis("property"); Returns the current value of a particular property in the analysis window.
Example: Get the number of trial modes used in the eigensolver.
Nmodes = getanalysis(“number of trial modes”);
Getting Results and Analysis:
Command
Description
nummodes
Returns number of modes found
Example:
findmodes
Calculates the modes supported by settings. This is equivalent to pressing the "Calculate Modes" button in the modal analysis tab.
frequencysweep
Runs a frequency sweep. This is equivalent to pressing the "Frequency Sweep" button in the Frequency analysis tab.
selectmode
Selects the mode by mode number in mode list
overlap
Returns the overlap and power coupling between two modes
bestoverlap
Returns the name of the mode with highest overlap with a specified mode
Example 1: Perform a frequency sweep on the first mode and plot the dispersion.
switchtolayout;
findmodes;
selectmode(1);
setanalysis("track selected mode",1);
setanalysis("detailed dispersion calculation",1);
frequencysweep;
D=getdata("frequencysweep","D");
f=getdata("frequencysweep","f_D");
plot(c/f*1e6,D*1e6,"Wavelength (um)", "Dispersion (ps/nm/km)");
Example 2:  Find out which mode in the mode list has the best overlap with the D-Card named " test_mode."  and return its effective index.
mode_name = bestoverlap("test_mode");
neff = getdata(mode_name,"neff");
To get data from particular modes, you can use getresult or getdata commands.
