Parametric sweep exits with error message: Parametric setup1- Invalid solution selection for goal calculation: No solution data.
This error message indicates that the entry in Calculation Tab of parametric sweep setup can not be evaluated for some reason. Usually that happen after the user modifies the setup without checking how the modifications affect the parametric sweep options."The on-page text should be modified as "This error message indicates that the entry in Calculation Tab of parametric sweep setup can not be evaluated for some reason. Usually that happens after the user modifies the setup without checking how the modifications affect the parametric sweep options.
See the attached pdf for more details:
Solution Document
