You may have spent a lot of time generating mesh as it is the most important, time-consuming, and complex task to carry out. Ansys Fluent meshing brings a new user-friendly way to generate quick mesh by maintaining results accuracy.
In this video, you will learn to create surface mesh on the car using options such as the body of influence, proximity, curvature, and face sizing. Also, you will explore the boundary layer setup and finally create a poly hexcore volume mesh.
