This lesson covers the mesoscopic lattice Boltzmann methodology, a crucial concept in understanding two-phase flow and heat transfer. It delves into the algorithm for solving multi-phase flow using this methodology and provides a practical demonstration using freeware. The lesson also explains how to install the software, set up model parameters, run a case study, and analyze the results. It further discusses the importance of collision and propagation in the lattice Boltzmann methodology. For instance, the lesson uses the example of colliding bubbles to illustrate the application of this methodology.
01:55 - Solving two-phase flow using lattice Boltzmann framework.
05:49 - Concept of sharp and diffused interfaces in the lattice Boltzmann methodology.
07:55 - How to discretize the domain of the simulation in the lattice Boltzmann methodology.
15:24 - Probability density functions used in the lattice Boltzmann methodology.
22:35 - Dem of Palabos to perform lattice Boltzmann simulations.
- The mesoscopic lattice Boltzmann methodology is essential in understanding two-phase flow and heat transfer.
- The methodology involves an algorithm for solving multi-phase flow.
- The process of collision and propagation is crucial in the lattice Boltzmann methodology.
- Practical application of the methodology can be demonstrated using freeware.
- The methodology can be used to analyze results from a case study, such as colliding bubbles.
