Interface Tracking and Applications — Lesson 3
This lesson covers the concept of two-phase flow and heat transfer, focusing on interface tracking methodologies. It delves into the volume of fluid methodology, explaining how to understand reconstruction schemes of interface from the data of volume of fluid in different cells. The lesson also provides a case study using volume of fluid-based freeware, demonstrating how to install the freeware, set model parameters, run a case, and evaluate the results. It further discusses the finite volume approach, the discretization of the domain, and the conservation of mass, momentum, and energy. The lesson concludes with a detailed explanation of the JERIS flow solver, a freeware for two-phase flow simulations.
Video Highlights
02:15 - Finite volume approach and it's usage to discretize the domain.
15:35 - Front Tracking Methods.
22:49 - Introduction to the Jeris flow solver.
33:57 - Case study on Rayleigh instability.
Key Takeaways
- Interface tracking methodologies are crucial in handling two-phase flow computationally.
- The volume of fluid methodology is a key method for tracking interfaces in two-phase flow.
- The finite volume approach involves discretizing the domain into small control volumes.
- The JERIS flow solver is a useful freeware for two-phase flow simulations, allowing for grid adaptation and interface reconstruction.
- The lesson provides practical insights into using volume of fluid-based freeware for two-phase flow simulations.
