Understanding Separated Flow Model-4 — Lesson 6
This lesson covers the in-depth analysis of the separated flow model in fluid dynamics. It discusses the derivation of mass momentum and energy equations for two phases taken separately and their combination to obtain the mixture momentum equation. The lesson also explores the condition of choking for the two-phase fluid model and the effects of change of phase. It further explains the concept of void fraction and its role in preventing compound choking. The lesson concludes with the discussion on empirical approaches to estimate the frictional pressure gradient and void fraction, and the Lockhart and Martinelli correlation.
Video Highlights
00:17 - Introduction to the separated flow model and its importance in understanding the condition of choking for two-phase fluid models
05:36 - Explanation of the empirical approach used to estimate the choking and the conditions under which it is applicable
08:47 - Discussion on the concept of two-phase multipliers and how they are used to express the frictional pressure gradient for two-phase flow
12:54 - Explanation of the assumptions made in deriving the empirical correlations for the separated flow model
45:55 - Discussion on the Lockhart and Martinelli correlation and how it is used to relate the two-phase multipliers and the void fraction to independent variables of flow.
Key Takeaways
- The separated flow model in fluid dynamics involves the analysis of two phases taken separately and their combination.
- The condition of choking in a two-phase fluid model is a crucial concept, which is influenced by the void fraction.
- The void fraction can adjust itself to prevent compound choking even when the two phases are separately under choked flow conditions.
- Empirical approaches are used to estimate the frictional pressure gradient and void fraction.
- The Lockhart and Martinelli correlation is a significant empirical approach in the separated flow model.
