Understanding Separated Flow Model-2 — Lesson 3
This lesson covers the concept of the separated flow model in fluid dynamics. It delves into the understanding of how different phases of a fluid interact with each other and the wall of the container. This lesson covers the detailed analysis of the separated flow model in fluid dynamics. It discusses the derivation of the continuity and momentum equation for phase one and phase two, and how these equations are affected by mass transfer and phase changes. The lesson also explains how to express the pressure gradient equation in terms of known input parameters. It further elaborates on the mixture pressure gradient equation and the mixture energy equation. The lesson concludes with the calculation of pressure drop from known input parameters and the derivation of the acceleration pressure gradient.
Video Highlights
4:01 - Explanation of the mixture energy equation
6:12 - Explanation of the acceleration pressure gradient
9:04 - Derivation of the pressure gradient equation
13:21 - Final expression of the acceleration pressure gradient
30:32 - Equation for total pressure gradient
43:44 - Discussion on the condition of choking for phase one and phase two
51:52 - Explanation of the need for empirical correlations to predict the frictional pressure gradient and the void fraction
Key Takeaways
- The separated flow model in fluid dynamics involves the analysis of two fluid model, continuity and momentum equations for different phases, and the impact of mass transfer between phases.
- The pressure gradient equation can be expressed in terms of known input parameters, providing a useful tool for calculations in fluid dynamics.
- The mixture pressure gradient equation and the mixture energy equation are derived and explained, providing a comprehensive understanding of these concepts.
- Pressure drop calculations from known input parameters are discussed, providing practical application of the theoretical concepts.
- The acceleration pressure gradient is derived, further expanding the understanding of pressure gradients in fluid dynamics.
