This lesson explains the minimum requirements for IMT-2020 and the calculation of user throughput, spectral efficiency, and area traffic capacity. It also covers the concept of peak efficiency and average spectral efficiency. It delves into the calculation of peak data rate and peak spectral efficiency. This lesson also covers the user experienced data rate and how it is calculated. It concludes with area traffic capacity and latency.
00:18 - Introduction and recap of previous lesson
04:05 - Minimum requirements for IMT-2020
10:58 - Peak spectral efficiency and how it is calculated
12:43 - User experience data rate and average spectral efficiency
24:31 - Area traffic capacity and latency
28:41 - Energy efficiency and reliability
- The 5th generation system is defined through the description of different scenarios.
- The important performance evaluation metrics vary for different scenarios.
- Advanced modulation coding, non-orthogonal multiple access, advanced multi-antenna techniques, and methods for increasing spectrum efficiency are vital for the evolution towards 5G.
- The minimum requirements for IMT-2020 include peak data rate, peak spectral efficiency, user experienced data rate, and area traffic capacity.
