Troubleshooting IDA Solver Failed Error while using ECM Model
Facing the issue while running the case with the Battery module, ECM model. The run has stopped due to the following error? Ida solver failed when calling echem submodel in a normal call: Vp=1.924120 Vn=-0.00029 IDA returns error code: -1 ida_check_flag
HPPC data fit is very important for Ansys Fluent to run ECM model without any issues. So, if the above issue is encountered, one needs to plot HPPC data (Voltage vs time) and check if the plots are similar for all SOC levels or not.
For more details, please refer to the document below:
