Monitoring Current Value using MSMD Battery Model
How do you use the MSMD battery model to monitor the current value?
If you want to monitor the current value in the calculation of the charge and discharge of the pulse conditions and driving conditions, you can use the volume monitor to see the current
values being used.
For more details, please refer to the document below:
