Selecting a Query by Name and then Exporting it
Using Python, how can a query be selected by name and exported?
The following Python commands will return the query id based on keyword for the query name, select the query based on the id, then export the query to a .csv. The -1 is necessary since the query IDs start from 1, while the number of the query used in the save commands start from 0. So there's an offset of 1 that needs to be taken care of.
queryid=ensight.objs.core.QUERIES.find('queryname*', wildcard=1, group=0)[0].ID
ensight.curve.select_begin(queryid - 1)
ensight.curve.save("csv",str)
