0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Which type of failure is observed in composites but not in metals? Select the best option.
What is the purpose of reinforcement in a composite material? Select the best option.
In layered composites, what can be modified to meet the required stiffness and strength properties? Select the best option.
Identify two components in aircraft structures where layered composites are widely used.
Which manufacturing process involves injecting liquid resin into a closed mold? Select the best option.
Which of the following benefits are possible with composite materials? Select the best option.
What is the main difference between short and long fiber reinforced composites? Select the best option.
Which types of composites are commonly used in engineered structures? Select the best option.
Identify two applications from the sports industry where layered composites are being used.
Which composite manufacturing process is commonly used to produce cylindrical structures such as pipes and pressure vessels? Select the best option.
