Ansys Student software can be downloaded for free here.
A turbulent flow exhibits small-scale fluctuations in time. It is usually not possible to resolve these fluctuations in a CFD calculation. So, the flow variables such as velocity, pressure, etc., are time-averaged. Unfortunately, the time-averaged governing equations are not closed (i.e., they contain fluctuating quantities which need to be modeled using a turbulence model.) No turbulence model is currently available that is valid for all types of flows and so it is necessary to choose and fine-tune a model for particular classes of flows.
In this exercise, you'll be turned loose on variants of the k-ε model. But in the real world, tread with great caution: You should evaluate the validity of your calculations using a turbulence model very carefully (which, ahem, means that there is no getting away from studying fluid dynamics concepts and numerical methods very carefully). Fluent should not be used as a black box. The k-ε models consist of two differential equations: one each for the turbulent kinetic energy k and turbulent dissipation ε. These two equations have to be solved along with the time-averaged continuity, momentum, and energy equations. So, turbulent flow calculations are much more difficult and time-consuming than laminar flow calculations. This is an exercise to whet your appetite for turbulent flow calculations.
Since the flow is axisymmetric, the geometry is a 2D rectangle. We will first use a 100x30 mesh (i.e., 100 divisions in the axial direction and 30 divisions in the radial direction). This will introduce you to the art of modifying meshes in the Ansys Workbench Mesher.
