Simulation Quiz — Electrothermal Simulation
Total Available Time - 45 mins
Total Number of Questions - 4
Times up!
Electrothermal Simulation — Simulation Quiz
Total number of questions - 4
Before starting the quiz simulate the rectangular edge fed patch antenna using Antenna Toolkit.
Solution frequency = 6 GHz and substrate material = FR4 epoxy.
Perform electrothermal analysis with the following settings. For each case, create a new design and rename it.
Case A: Same flow as the workshop video without a power block.
Case B: Same as case A with inlet Y velocity = 1 m/s.
Case C: Turn off radiation model, set inlet Y velocity = 0 m/s.
Case D: Simulate the rectangular edge fed patch antenna using Antenna Toolkit.
Solution frequency = 6 GHz and substrate material = Bakelite.
Perform electrothermal analysis with inlet Y velocity = 1 m/s.
1 / 4
In case D, plot temperature on all objects. What is the range in which maximum value of temperature lies?
2 / 4
In case C, what is the change in temperature as compared to case A?
3 / 4
In case B, plot velocity vector in Air region. What is the range in which maximum value of velocity lies?
4 / 4
In case A, plot temperature on all objects. What is the range in which the maximum value of temperature lies?
Your score is
0%
