Why the incident wave from the inlet of a pipe is usually specified as an acoustic excitation (e.g., velocity or mass source) and not pressure?
Tagged: 19.2, Acoustic, acoustics, excitation, incident waves, mechanical, structural-mechanics
April 5, 2023 at 2:32 pm
FAQ
ParticipantIf one has an acoustic analysis of pressure waves in a pipe-like system, by specifying a known Pressure, one would be saying that the total pressure must be “x” value. Therefore, the equivalent ‘incident” pressure from the end of the pipe would actually vary as a function of frequency, which is usually not desired. Therefore, for acoustic analyses, the incident wave from the inlet of a pipe is usually specified as an acoustic excitation (e.g., velocity or mass source).
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- Model has a large number of contacts – how to reduce them?
