Tagged: 17, fluent, fluid-dynamics, post-processing, Species/Reactions, Surface Chemistry
August 25, 2023 at 12:15 pm
FAQParticipantIt is possible to see a surface reaction at the end of the streamlines of the wall, with the direction of the velocity vector toward the wall. This is physically correct. By the decomposition reaction of gaseous species, the rate on the wall will not occur. This speed is dependent on the deposition rate of the gas species is deposited on the wall (Deposition Rate). By checking the mass flux balance in all of the border, including a reaction wall, mass flux flowing into the reaction wall will be clear.
1. 2041851.pdf
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Configuring and Solving the Chemical Species Transport in Fluent
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
