January 25, 2023 at 7:17 amFAQParticipant
This could arise if the “mean diameter” (d_bar) used in the curve fit calculations does not correspond to a cumulative mass fraction (Yd) = 0.368. Note that the “mean diameter” required in the curve fit calculations may not equal the actual Sauter-mean diameter value. Rather, the mean diameter used in the calculations makes the ratio d/d_bar = 1, so that Yd = exp(-1) = 0.368. Thus, Yd < 0.368 for larger particle diameters where d > d_bar, tending towards zero for the highest diameter. On the other hand, Yd > 0.368 for smaller diameters where d < d_bar, tending towards unity for the lowest diameter.
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Mixing Tank Modeling in ANSYS Fluent
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- Hydrodynamics and Wave Impact Analysis
- What is the superficial velocity in multiphase flows?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Simulation of Exhaust Gas Recirculation (EGR) Cooler with CFD
- What do “incomplete” DPM particle tracks mean?
