Why doesn’t surface load applied with SF in a *DO-loop that loops through the nodes on the surface get applied?
Tagged: 16.2, apdl, Macros/Scripting/UPF, mechanical-apdl, structural-mechanics
March 17, 2023 at 8:59 am
FAQParticipantAn SF command is ignored if the selected nodes don’t define a face of an element. Applying SF to a single node doesn’t work.
