Why are boundary conditions incorrect after a post1 combination of harmonic real and imaginary results?
Tagged: 9, General, mapdl, Mechanical APDL (f. ANSYS), structural-mechanics
March 17, 2023 at 8:59 am
FAQ
ParticipantThe real component of applied loads is stored with both the real and imaginary results, so the combined value reflects that. For example, if an SRSS combination is done, the combined value will be the real value times the sqrt(2) regardless of the actual imaginary component of the load. Due to this effect it is not possible to re-enter solution and solve with the combined boundary conditions.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
