Tagged: 19.1, General, mechanical, structural-and-thermal, structural-mechanics, transient
March 17, 2023 at 9:00 am
FAQ
ParticipantThe thermoelastic damping matrix is probably the source of the problem. Add “keyopt,matid,9,1” for all of the coupled-field bodies.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
