Tagged: 2019 R1, fluent, fluid-dynamics, General - FLUENT, udf
March 17, 2023 at 8:59 am
FAQ
ParticipantThis is generally used when looping over faces of an internal surface which shares partitions across the surface. This macro helps to use the principal face and avoids repetition of calculations, for example when calculating the face area.
- Skewness in ANSYS Meshing
