Tagged: 2021 R1, fluent, fluid-dynamics, General, Modeling/Setup Advice, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantWhen you use the chemical species model, the default number of species that can be included in Mixture Material is as follows: •R19.0 and later: up to 700 •R15.0 up to R18.0: up to 500   •R14.5 and earlier: up to 50 There is no limit to the number of registrations in order to register the property on the Material panel In a model that does not solve the equations of each species’ mass fraction, such as the diffusion combustion model, you can use more than the usual maximum number of chemical species. The upper limit will follow what is set in Table Parameters. The number of reactions that can be registered is Fluent 6.3 in 1500. There is no exact upper limit in later versions.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Configuring and Solving the Chemical Species Transport in Fluent
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
