What causes the following error? ———————————- Error in subroutine GET_VARVX : OLD : Failure to get data area USER_AV1_FL2 GETVAR originally called by subroutine SU_DVAR_ZONE
April 5, 2023 at 2:32 pm
FAQParticipantThe error typically occurs in the solver frontend output during the solver initialization, e.g. immediately after the domain Interface information was printed to the out file. In that case it is often caused by the fact that different models are used on both sides of the fluid fluid or fluid porous interface, e.g. a transported Additional Variable is only defined in one domain or the turbulence models are different. If the error message before refers to a recursion problem, please refer to solution ##815988
- Skewness in ANSYS Meshing
