Material Properties
Material Properties
The program uses DEFA for ERESX by default, which will not do extrapolation for elements with plasticity. Why is the maximum stress still higher than the yield stress defined by the bilinear isotropic hardening rule?
    • FAQFAQ
      Participant
      The problem is that extrapolation is still implemented when the stress is close to the yield point. It introduces the error.
