Tagged: 19.2, fluent, fluid-dynamics, MP - Particle Tracking, multiphase
January 25, 2023 at 7:17 am
FAQParticipantData from simulations using the Dense Discrete Particle Model in Fluent are not forward compatible going from older versions to Fluent 19.2 and later. This due to a change in the number of DPM field variables used by the model. When reading a 19.0 cas and dat into 19.2 you will get an error when reading the dat file indicating “skipping data” as it is of “wrong size”. It is not recommended to use this data even as a starting point to continue iterations.
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- Guidelines for Courant Number for steady and transient simulation.
- Mixing Tank Modeling in ANSYS Fluent
- What is the meaning of VOF courant number and Global courant number in ANSYS Fluent Multiphase Model and how are they related?
- What is the superficial velocity in multiphase flows?
- How do I use porous media in a multiphase flow?
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
