Problem/Description: How to create geometry of a “microstructure” (made of fibres) that may be used in a simulation of flow through the resulting pores?
March 17, 2023 at 1:10 pm
Solution
ParticipantPlease find the attached solution. Please note that this solution is prepared by our Channel Partner – ENTUPLE
1. 1. CPSolution_pre_processing.pdf
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
