August 25, 2023 at 12:15 pm
FAQ
ParticipantYes, it is possible to use a UDM with the Eulerian model. By using the C_UDMI(c, t, i) macro (i being the UDM number), it is possible to save any numerical value for each cell. This data is used well in a UDF and is a very useful feature because it is also saved in Fluent data files. However, when using the Eulerian model, it requires attention. In the Eulerian model has three thread case of the calculation of, for example, two-phase. 1. mixture thread (thread of mixture thread phase) 2. Primary Thread (thread of the first phase) 3. Secondary Thread (thread of the second phase) Some variables have to have a value only at the primary / secondary thread and other variables have a value only at the mixture thread, but the UDM has a value only at the mixture thread. For this reason, it is not possible to save the numerical value for each phase even in the Eulerian model, you can save only one number from each cell. If you want to save the numerical value of each phase, you need to use two UDMs. Keywords: multiphase, UDM, user-defined memory, user defined memory, Euler, phase thread
1. 2043325.pdf
- Solver message during DPM calculation: “number of stepsize underflows during particle integration step is x”. What does it mean and how to get rid of it?
- What is the difference between the VOF model and the Eulerian model?
- ANSYS Fluent – Eulerian & Mixture Multiphase Models & Applications – Tips and Tricks
- ANSYS Fluent: Efficient Modeling of Spray Breakup using VOF-to-DPM Transition
- What is the superficial velocity in multiphase flows?
- Mixing Tank Modeling in ANSYS Fluent
- Hydrodynamics and Wave Impact Analysis
- ANSYS Fluent: Describing Cavitation in a Centrifugal Pump
- How do I use porous media in a multiphase flow?
- What do “incomplete” DPM particle tracks mean?
