Is it possible to do a modal analysis with support stiffness that varies as a function as a frequency?
April 5, 2023 at 2:32 pmFAQParticipant
No, frequency dependent material properties are not supported in a modal analysis because the frequencies are unknown.
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- How to include effect of bolt pretension in a modal analysis?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
- Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
- ANSYS Mechanical: Vibration Housing Noise
