In WB-Mechanical Additive Manufacturing using Cartesian meshing option, what is the cause of Error Message: Element ‘x’ (corresponding to layer n) has a mesh thickness of ‘y’ that not consistent with the other elements (thickness=’z’). The mesh must have the same thickness for each layer.
March 17, 2023 at 8:59 am
FAQParticipantThis can happen when the interface between the build body and supports in nonplanar. One workaround is to merge build and support(s) into a single multibodied part. The build and supports are still distinct bodies, but they will now share common nodes at interface.
