In R18, Is it possible to delete the ln22 files to reduce hard disk space in the context of CMS with RBD ? How it is possible to do it ?
June 5, 2023 at 7:04 amFAQParticipant
With the default option (ELCALC set to no in CMSOPT command), we must keep the ln22 files, because they are used in the subsequent expansion pass (along with the .cms file). With the new option in R18, ELCALC may set to yes in CMSOPT command, and ln22 files may be deleted, because all the modes of the transformation matrix as well, as the elemental results, are stored only in the .cms file which is sufficient for the expansion pass. With this option, the size of the .cms file will increase compared with the default approach. To delete the ln22 file, just issue SEOPT,CPXXX,2,,,NONE in a command snippet inserted below the condensed part, keeping in mind ELCALC must be set to yes in CMSOPT. Therefore a useful command insert (below the condensed part) would be the following : CMSOPT,FIX,6,,,,,CMS,,RBD,YES !specifies CMS analysis options SEOPT,CPXXX,2,,,NONE !specifies substructure analysis options
- Why is damped frequency is lower than undamped frequency with viscous damping but larger with structural damping?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How can I specify acceleration at a node? Could I use the ‘big mass method’?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- Is it possible to perform a sine-on-random vibration analysis in either Mechanical or Mechanical APDL?
- In a Modal Analysis of Mechanical, why aren’t the Participation Factors Summary under Solution Information displayed?
- How to include effect of bolt pretension in a modal analysis?
- ANSYS Mechanical: Vibration Housing Noise
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
