June 6, 2022 at 9:57 amFAQParticipant
The file.cnd file has the contact force component data for each contact pair:
Contacting Area Total contact force due to pressure -x component Total contact force due to pressure -y component Total contact force due to pressure -z component Total contact force due to tangential stress -x component Total contact force due to tangential stress -y component Total contact force due to tangential stress -z component One can use trackers to extract data.
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
