June 6, 2022 at 9:58 am
FAQParticipantThe CINT command is used to calculate the fracture mechanics parameters. The CINT command cannot be used with SHELL elements. SOLID elements are required. For a thin structure, you could use an overall surface model with SHELL elements and a local submodel with SOLID elements. The fracture mechanics parameters could be evaluated for the submodel.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
