June 5, 2023 at 7:05 amFAQParticipant
The R12.1 logic is backed up in R17.0. However, in R18.0, any contact logic prior to R15,0 are no longer supported. Note, the use of CNTR,REVISION,…is undocumented.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
- What does ambient temperature represent when using surface to surface radiation?
