Tagged: 17, General, hpc, mechanical, structural-mechanics
March 17, 2023 at 1:11 pmSolutionParticipant
Attached are two scripted demonstration PDF’s that discuss and show how to run parallel solutions; what information to gather; and a spreadsheet to show the performance.
1. 2017 HPC Evaluation on Existing Hardware Module 1.pdf
2. 2017 HPC Evaluation on Existing Hardware Module 2.pdf
3. 2052041.zip
4. ParallelWorkbook-Module1.xlsx
5. ParallelWorkbook-Module2.xlsx
- The LS-DYNA equivalent of *MODEL_CHANGE card (in ABAQUS). Which keywords can be used to introduce(activate)/delete(deactivate) elements in the middle of a calculation (at user-specific time/load steps).
- How to resolve “Error: Invalid Geometry”?
- After Workbench crashes, how can I recover the project from a .mechdb file?
- Model has a large number of contacts – how to reduce them?
