Multiphase Flows
Multiphase Flows
How can I calculate particle tracking in absolute reference coordinate system when using MRF?
    • FAQFAQ
      Participant
      Since particle tracking is based on the coordinate system, if Track in Absolute Frame is enabled, Particle tracking can be in the absolute reference coordinate system. Changes are made using the TUI command: /define/models/dpm/options/track-in-absolute-frame
